Use the following procedure to configure DHCP Snooping on a specific VLAN. If DHCP Snooping is globally disabled, the switch forwards DHCP reply packets (received on trusted or untrusted ports) to all ports.
If you enable DHCP Snooping globally, the agent determines whether to forward DHCP reply packets based on the DHCP Snooping mode of the VLAN and trusted state of the port.
You cannot enable DHCP Snooping on Private VLANs (E-Tree) and SPBM B-VLANs.
You must enable DHCP Snooping globally.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface vlan 5 Switch:1(config-if)#ip dhcp-snooping enable
The following table defines parameters for the ip dhcp-snooping command.
Variable |
Value |
enable |
Enables or disables DHCP Snooping on the specified VLAN. |
